Can anyone advise how much the amount of memory (512 vs 1024M GDDR5) influences the heat production and power consumption.
The Sapphire HD 6670 512MB is only 3£ cheaper compared to the 1024M version if taken the delivery costs into account (buying the 1024M not from OC).
However, the card will go into a ITX build in a SG06 case. So I'm more concerned about the heat production and power problem.
Is 512 Mbyte enough for a 1400x900 monitor ?
Thanks
Thanks
