- 18 Mar 2007
Realistically, will I notice much difference using wireless to connect to the internet rather than running a CAT5 cable up through the house? ie for general stuff and games?
2 options -
Option 1 - run cable up wall in corner of hall and up through ceiling - remove floor boards in landing and study and feed cable through to PC.
Pros - get a hard line from router to PC. quiker more stable connection
Cons - Pain in the @rse to do, but I should be able to manage it.
Cost - About £50 for pre crimped cable ?
Option 2 - buy a PCI wireless network card and go wireless.
Pros - Easy, quick and cheap. Not much slower or less stable than a cable ?
Cost - About £30 ?
Any views? or things I haven't thought about ?
Cheers
Nic
2 options -
Cost - About £30 ?
Cheers
Nic
