14 Feb 2015 at 16:33 #1 chippy08 chippy08 Soldato Joined 21 Sep 2008 Posts 4,020 Which mini itx board for the pentium k so it can be overclocked to around 4.5ghz but not too exspensive.
14 Feb 2015 at 16:38 #2 Telecaster Telecaster Soldato Joined 17 Jun 2012 Posts 5,951 How much do you want to spend? This should do it: YOUR BASKET 1 x Asus H81I-Plus Intel H81 (Socket 1150) DDR3 Mini ITX Motherboard £58.99 Total : £64.97 (includes shipping : £4.98).
14 Feb 2015 at 17:54 #3 chippy08 chippy08 Soldato OP Joined 21 Sep 2008 Posts 4,020 Yer up too £70 would be ok
14 Feb 2015 at 22:29 #4 Tute Tute Soldato Joined 24 Jul 2004 Posts 22,593 Location Devon, UK Can't really argue with the suggestion above, you're not going to get better without a boost to your budget or by going second hand. And even then, it would only be worth it if you wanted the Z87 or some other feature like wifi, mSATA etc.
15 Feb 2015 at 11:04 #5 chippy08 chippy08 Soldato OP Joined 21 Sep 2008 Posts 4,020 Tute said: Can't really argue with the suggestion above, you're not going to get better without a boost to your budget or by going second hand. And even then, it would only be worth it if you wanted the Z87 or some other feature like wifi, mSATA etc. Click to expand... Apart from reviews are pretty poor like boards breaking with in months or weeks and i don't want the Asus Rma Nightmare
15 Feb 2015 at 13:25 #6 pastymuncher pastymuncher Man of Honour Joined 12 Jul 2005 Posts 21,523 Location Aberlour, NE Scotland There's no guarantee that a H81 board will work with a G3258 out of the box without a bios update either.
