Which mobile to get ?
18 Oct 2002
Nottingham
Hello,
My 3310 has given up :p not bad that 6 years old and its had some hammer.
Looking for a new phone but not sure what to get.
I need to beable to take my old sim card and use it in my new phone. I am with Orange pay as you go.
I work on a building site so the phone needs to be tough.
The only one i have seen is the Nokia 5140I, dont have blue tooth though which i would like. Cheapest i can find it for is £160 which is alittle expensive.
Anyone recommend any others ?
Thanks Ben
6310i is imposable to break, not a great phone any more (ry to look past the screen) but has bluetooth and a few other bits so might do the job for you. Should be able to get one for around £40 now.
