Well, after far too much deliberation, I've finally managed to narrow my new monitor shortlist down to these two: the NEC EA231WMi, a brand new release boasting 23" of e-IPS goodness, and the 22" e-IPS Dell 2209WA, which has a lower res but 16:10 aspect ratio (1680x1050 vs 1920x1080 on the NEC).
So then guys, which one? I'm upgrading from an ancient 17" Vusys HD17A, so the extra inch of screen estate lost with the Dell isn't likely to be an issue for me, but it's the age-old 16:10 vs 16:9 debate that's really chewing me up. Usage will mainly be Photoshop work and Full HD video editing, along with the obvious email and web browsing. I also game occasionally, but nothing serious.
I'm very much drawn towards the NEC, purely for the fact that the higher resolution will mean I won't have to downscale when viewing raw HD footage, but my only concern is that I will regret the vertical space lost in not getting a 16:10 screen. I've used 16:9 monitors in the past and found this to be the case, but they were only 19". Will the extra four inches of the NEC offset this? Is the widescreen aspect ratio likely to be enough of a hindrance that I'd be better off with the lower res panel?
Any opinions you could give will be much appreciated, and obviously I do understand that this sort of thing can be pretty subjective. Thanks!
