which monitor? - on a budget
16 Nov 2005
Torquay
Hi im after a new 19" LCD monitor, my budget is 195.
I like the look of the Samsung SM-920N is this a good choice?
Sorry but i dont have a clue when it comes to monitors.
thanks.
for your budget, you probably won't find much better than the 920N (previously 913N). When similar questions have been asked in the past as well, the ACer AL1916W and Neovo F419 frequently pop up, but i dont think you can go wrong with the 920N tbh
