Which Monitor to buy
2 Jan 2014
I have decided to buy a monitor with a high refresh rate to replace my 4K 60Hz Acer CB280HK, I'd like it to be G-Sync compatible and I have about £400-£500
What would you advise?
Monitors are all about compromise, on the plus side you don't need G-Sync anymore for nvidia cards but you're limited to displayport with Freesync / nvidia combo.
How high a refreshrate rate do you want? What resolution? size? display type? VA TN, IPA?
