Which monitor to go with 88000 GTX (and DVI questions)?
13 Feb 2007
Costa Del Sol
Hi I'm wondering which monitor is a good choice with the GeForce 8800 GTX with a budget of up to £250ish? I bought my build yesterday but see now the monitor I bought (Belinea 22") has no DVI input so am going to be changing it. Now I don't understand DVI too well but I see the GeForce card supports it ( "Dual dual-link DVI supports two 2560 x 1600 resolution displays - HDCP Enabled!!") and it seems the best way to connect the gfx and monitor and is it best to have DVI for future (what is DVI used for basically - I'm a n00b go easy on me)? So a monitor without DVI input is no use to me if I'm buying this card right?
Monitors I'm looking at on OcUK are:
V7 L22WD 22" Widescreen LCD Monitor
Samsung SM-205BW 20" Widescreen LCD Monitor
Dell E207WFP 20" Widescreen LCD Monitor
Or if these are good I might be prepared to wait for these to come in stock (20 or 22") :
Samsung SM-206BW 20" Widescreen LCD Monitor
I've seen it mentioned (on here somewhere) that a 20" is going to be sharper than a 22" because they have the same amount of pixels so in a 20" the pixels are more compact, is this true? What are the pros and cons of 20" v 22" please? I'll be using it for games and general surfing etc.
Thanks in advance for any advice, I've already had great advice on my build from here so far. :)
it would be cheaper to use one of the two dvi>vga converters you get with the card..... i've got a monitor and a sony hdtv connected to my 8800gtx, both using dvi>vga converters:)
I have the 8800gtx running on the belinea and it looks awesome, no blurriness or anything sharp as a tack, it's just as good as the v7 or the other 22"'s for the same price on the market, dark colours look strange on it though but i think that's just due to it being a tn film panel and nothing to do with dvi or vga.
Hi sorry not responded sooner, so the GTX (and GTS?) come with the converters then???? Is that as good as having a DVI input on the actual monitor?
get a monitor with DVi input its better then using converter.
When using converter, the image is converted from digital to analogue.
The dual link thing is, if you have a HD monitor and that supports high res you can use a dualink DVi cable.
Most monitors use normal Dvi cables and don’t support HD res unless you buy HD monitor
DVI Dual Link can display a resolution of up to 2048x1536, DVI Single Link can display a resolution of up to 1920x1080 (notice 1080 is a HD resolution, aswell as 720) so DVI Single link cables support HD resolutions..
Dual Link DVI just means the pins have double the power of transmission which gives better signal quality.
<edit> Regarding the OP; getting a monitor with DVI is usually better because it gives you a VGA connection aswell, so you can plug something like a xbox 360 in to it. Some people will argue that DVI is noticable better quality than VGA but others will say they can see no difference. Personally I prefer a monitor with a DVI input.
they come with two convertors, and there's no problems with mine. running at 1080p with a 10ft vga lead is about on its limits though, there is a small amount of noise visible on test images, but other than that its top stuff.
