Which monitor would you use?
Permabanned
3 Aug 2009
Manchester
Hi guys.
Which monitor should I chose for my Xbox 360?
I can't link it as it'd class as competitor, but it's an AOC 21.5" Full HD monitor and a Hanns G 22" monitor.
Is it worth losing the full HD for an extra 0.5" ?
I'm buying it from a local retailer that only stoke these 2 so I don't have a choice to buy anything else.
That seems like a fairly bad reason to limit yourself. Are you getting some sort of discount to make you have to buy from there? If not I'm sure you'd be able to get a better deal online.
I'd save a bit more and treat yourself to something a bit better than either of them.
I am getting a discount from there. And I'm also on a tight budget so it makes sense. I wouldn't be able to afford any of the bigger ones anyway.
What I'm not sure of is to go with the 21.5" HD or just the standard 22"
Go with the full HD then. The picture will be much sharper as the dot pitch of the pixels will be smaller with there being more of them.
