which monitor?
18 Feb 2007
London
hi
ive just ordered my pc , but have yet to order my lcd ,what would you recommend for this spec below , i dont want to spend loads on a monitor but i would like something decent , someone did suggest the belinea 22" lcd which looks good?
Seagate Barracuda 7200.10 250GB ST3250620AS SATA-II 16MB Cache - OEM £46.99
(£55.21) £46.99
(£55.21)
OCZ 2GB (2 x 1GB) PC2-6400 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK) £97.99
(£115.14) £97.99
(£115.14)
BFG GeForce 8800 GTS OC 320MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail £164.99
(£193.86) £164.99
(£193.86)
Pioneer DVR-111BK 16x16 DVD±RW Dual Layer ReWriter - (Black) OEM £18.99
(£22.31) £18.99
(£22.31)
Lian-Li PC-7 PLUS Aluminium Midi-Tower Case - Black £49.99
(£58.74) £49.99
(£58.74)
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU (CMPSU-520HXUK) £59.99
(£70.49) £59.99
(£70.49)
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail £101.99
(£119.84) £101.99
(£119.84)
Arctic Silver 5 Thermal Compound (3.5g) £5.99
(£7.04) £5.99
(£7.04)
Gigabyte GA_965P_DS4 (Socket 775) PCI-Express DDR2 Motherboard £94.99
(£111.61) £94.99
cheers
Would be best to know what your budget/ideal size is. But if your looking for a good quality cheap 22" then go for the Belinea.
No complaints about the Belinea, my housemate got one and he's been playing games at 1680x1050. Films also look good :)
I still prefer my dual 19s though :p
i would reccomend the viewsonic vx2025,its slightly more than your budget,but it does colours very well and ive found it very good for movies and games
thanks
is there anywhere in the highstreet that sells some good monitors such as the samsung or viewsonic ,
i would prefer a 20" max display as i think 22" is too big for me (not got that much room)
Take out the competitor links unless you fancy a vacation :D
i would wait for the sammy 206 bw 20ins
or the sammy 226 bw 22in both widescreens.
lots of good press!! :D but in stock nowere :rolleyes:
