I am currently looking at a cheap (due to brand name) 22" monitor. It has the following specs:
Response Time 5ms
Contrast Ratio 1000:1
Brightness 300 cd/m²
Max. Resolution 1680 x 1050
View Angle:
Horizontal: 170°
Vertical: 160°
Only problem is, it uses your usual DB-15 analog connector. Now, if I were looking at a DVI connection for my monitor, I'd have to drop down in size, probably to a 19" (20" at a push - sticking to budget.)
Will there be a major difference between the VGA and DVI connections, leading me to the DVI 19", or should I go for the 22" VGA?
Response Time 5ms
View Angle:
Horizontal: 170°
Vertical: 160°
Any foreseeable lack of quality using VGA over DVI? It seems like a nice monitor, but the VGA/DVI thing is bugging me.
