Which monitor??
15 Apr 2007
I am currently running on 17" crt and have been thinking about upgrading for a while now, but which should I go for, bearing in mind I'm on a tight budget.
Was looking one of a couple of options at the mo
Belinea 19": http://www.overclockers.co.uk/showproduct.php?prodid=MO-005-BE&groupid=703&catid=17&subcat=276
LG 20": http://www.overclockers.co.uk/showproduct.php?prodid=MO-046-LG&groupid=703&catid=17&subcat=948
A friend of mine has the Belinea and has given it a favorable recommendation to me and for the price it seems good value, as does the LG (which is right up at the top end of what I was looking to spend). I'm only really considering the LG because of the larger screen size and don't really wanna spend a similar amount on a 19", so really these are my 2 options.
Finally my 8800gts 320mb should be ok with these resolutions for gaming shouldn't it?
Anyone care to help me out here, I may be dropping into OC tomorrow to pick one up, but the Belinea is outta stock, so may go for the LG anyone have any thoughts?
