When looking at the mid to high end Intel Z790 ATX boards, which manufacturer would you choose (for reliability mainly)?
Background to this question:
I'm building my first PC in 10 years. I tend to go for high-ish end and buy/upgrade infrequently. I'd been pricing up Asus parts (Z790 Hero, Asus 4070Ti, etc). I'd heared about previous issues with the Z690 Hero boards capacitor fault, but put that down to a one-off. However I've just heard about the issue also with the Z690 Formula boards block corrosion issue, and also how Asus have been apparently ignoring the issue until very recently. It seems most put this down to a cost saving matter, which is in contrast to its price. Either way, a faulty motherboard is one problem I'd rather avoid.
The chances are I'd air cool the build, and my understanding is the corrosion fault only happens if you use liquid cooling(?), but either way the whole thing is worrying.
This has knocked my confidence in Asus as my first choice. Are my doubts warranted, and if so, what are your guys preferred manufacturer (and/or equivalent board to the Z790 Hero)?
Many thanks
Many thanks
