having to rma a faulty crosshair II this week, which seems to be out of stock :/
which board would you choose from ocuk for around same price thats instock?
£190 to spend, has to be amd to match my phenom 9850, and pref support 1066mhz ddr2 natively
I have a 8800gt but I'm not bothered about using sli so doesn't have to have that.
was reading reviews of the Asus M3N-HT Deluxe, doesn't seem the best and has a fair few bios problems it seems on the asus forums.
Foxconn A79A-s possibly go for this one
Only problem being is i use watercooling which needs the 4holes around the socket to put screws up through for the mount and
Backing plate on that doesn't detach or is glued on... i assume the bolts will screw up through that though or?
