- 13 Aug 2004
- England
I need to top up my engine oil as the dip stick is showing it's running low (4 stroke 125cc) however i'm stuck as to which to use. It's a chinese import so the manual is a bit unclear, all it says is to use a multi degree luboil with a graph underneath.
I've been suggested to use 10w-40 part synthetic as i'm told it will mix with either synthetic or mineral oil.
