Which mouse for gaming?
18 Feb 2008
Hi,
I've recently started getting back into FPS games on PC and I need to buy a new mouse. I'm currently using a wireless Logitech M705 and while I will continue to use that for everything else, it's not very good when it comes to gaming.
I have relatively small hands so don't want anything overly big, and I'd prefer it not to be Logitech because I've had problems with their mice whining (G500s).
Does anyone have any recommendations (£50-60 max), at the moment I'm looking at the Roccat Kone Pure Core Performance Gaming Mouse but not sure if there's better alternatives?
Thanks in advance.
I'd say that Roccat or the Steelseries Sensei RAW with rubber top (the others suck they are not comfortable due to their gloss plastic surface). Unfortunately this one is out of stock everywhere, apparently cause that's the only RAW ppl are buying lol.
You can also buy the Corsair M65, its the one I have for the past year. Probably the highest quality build/appearance on the market (there is no cheapo plastic, its all aluminium chassis and rugged top). I think the laser is REALLY good (especially compared to my previous G500 (non-s)) and the clicks are very nice and short (no hollow **** like most razers). Only negative point is the wheel is not very durable, if you abuse it, it might end up not always working (when you click it as middle mouse button) after a year. Still worth its money.
I've gone for a Razer Deathadder but it is quite a large mouse so if you have small hands it's probably not a great choice.
Maybe a Zowie FK would be good for you as it's quite small and light? That was the other mouse I was considering getting.
I've actually returned my Razer Deathadder as I found it pretty uncomfortable even after only a couple of days use. The mouse itself just feels too big and the arch is too high. My forearm and wrist were sore after using it for only a couple of hours TBH.
Gone back to my Logitech MX Revolution!
