Which mousemat?
30 Oct 2003
Hemsworth
I use my computer while sitting in an armchair and wondered what mousemat would be good to put over the arm of the chair. It's a leather armchair and the arm is 9 inches wide. The leather itself works okay but I want better performance.
It needs to be a cloth mousemat (I have a hard steelseries one from back when I used a desk but it's too big and wobbles for this task)
I was looking at this
http://www.overclockers.co.uk/showproduct.php?prodid=GS-001-GI&groupid=702&catid=32&subcat=
but I'm not sure if it's flexible enough to sit comfortably on an armchair arm.
http://www.overclockers.co.uk/showproduct.php?prodid=GS-002-OZ&groupid=702&catid=32&subcat=
seems okay but I'd rather hear from someone who has one and can let me know firsthand - or maybe someone uses a mat in the same way I plan to.
Really wasn't sure where else to post this but it is for pc gaming so this seems as good a forum as any.
Thanks in advance!
Thanks for the suggestion but I think it might be overkill. Plus it's not clear how flexible it is for how I intend to use it (over the arm of a chair)
When I go to my mates house, who plays PC like you but with no mousemat, I normally take along my Steelseries QcK Gaming Mouse Pad (the really small one) and I get a place mat from his dinner table and put it on that on the arm of the chair (the arm is a flatish surface). It's not brilliant but needs must and all that as I just can't play any FPS on the arm of the chair without it.
As for advise; out of those two you have linked I would choose http://www.overclockers.co.uk/showproduct.php?prodid=GS-002-OZ&groupid=702&catid=32&subcat=. I have never used it before but it looks the same as the Steelseries one I have.
EDIT: I also have the BoogieBug XXXL mat (it's ******* awesome!), but I'm not gunna be as stupid to suggest to use that over the arm of your chair lol
You could use it as a mouse mat, then when you go camping, you can sleep on it for the ultimate glide and comfort.
iI use the Boogie bug. I have it cut up, with most of it on my desy but a part of it i have wrapped around a large book so that i can use it from the sofa:cool:
I imagine it would be fine for your use, on the arm of a chair. I have used it on my sofa before with no problems.
Now that they are back in stock i might pick up another one
It's very very flexible, and with the size of it you can make it any size you want with a decent pair of scissors :)
Honest m8 theres no mouse mat out there better :cool:
The boogies are very flexible and good, shame mine seems to always get dirty, still smooth'ish and mouse still tracks fine though
