WHich new system shall I get???
19 Sep 2007
My trusty Dell Dimension 9200 has finally given up the ghost and even a PSU replacement didn't help, so looking to upgrade and am kinda torn between the following 2 systems
naughty boy! or
http://www.overclockers.co.uk/showproduct.php?prodid=FS-366-OE&groupid=43&catid=2475&subcat=2602
Both systems are based on the i5 4670K models with 8gb ram, 1TB HDD and a GFX card with a total system value of around £650 mark
But not sure which one to go for or which is the most reliable..
Cheers
General hardware is your best bet, but in the meantime that system would be good. Are you going to use it for gaming? The default gfx card in that build isn't up to much so would recommend something better if so.
No need to worry about reliability, the systems have warranty and I've never had a failure on an OcUK system so far, other than a HDD failure which nobody has control over. (Damn you Seagate!)
