Which Noctua fans
27 Mar 2016
Bristolian living in Swindon
Hi all
I'm looking to get some fans to go in my build... I want the Grey Noctua fans but noticed there are a few variants, some have higher RPM and some are listed as 'quiet' others are 'high performance' will it make much difference which ones I choose?
Cheers
If you can control them I would get the performance ones that way you got the best of both worlds.
