Which nVidia 4xx card will do 3 monitors without SLI?
14 May 2009
Stupidly bought a 460 as I thought it would drive 3 monitors, but it turns out it'll only do 2 without SLI'ing it.
Will any of the 4xx series do a 3 monitor setup directly, 2 @ 1600x1200 and 1 @ 1920x1200?
TIA
P
Nope all current nVidia GeForce cards can only drive 2 monitors and for nVidia surround you need a pair of cards in SLI.
If your not interested in hardware 3D spanning (nVidia surround) then adding another cheap GPU will let you extend the desktop over 3 monitors.
I don't think games will work over the three monitors though if you do that
As I said it will only let you extend the desktop, incase of confusion I was referring to nVidia surround (accelerated 3D) when I said hardware 3D not 3D Vision surround.
Darn it, think the advertising is a bit misleading because they don't make the SLI requirement clear :( The machine may get used for a little FSX but it'd be in Windowed mode so I suspect I can get away with any old half decent 2nd card.
Ta
You said you would use a normal card and a crappy vga card for third?
Well if you try and play a game spanning these monitors it wont work, in window mode it will just fail.
Also that link...
ZOTAC announces the first Quadruple-display capable graphics card of the world
ATI have a Quad display card out ages ago... and also ati have 6 monitor cards....
Well assuming I would be sensible enough to have a card able to handle FSX then why could I not put one window on each monitor? I appreciate having one large window spanning the output of 2 cards might fail but if each screen has it's own window that should be ok shouldn't it?
