Which of these is better?
25 Apr 2011
Blackpool
I'm looking to get a 27" 1080p monitor, which of these (or another for similar price) do you think is the best?
http://www.overclockers.co.uk/showproduct.php?prodid=MO-077-IY&groupid=17&catid=1120&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=MO-083-IY&groupid=17&catid=1120&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=MO-054-IY&groupid=17&catid=1120&subcat=
They all have similar specs and similar pricing, the first cheaper one has lower responce time but i figured must fall short somewhere else seeing as its cheaper. The second and third are the same price, and look to be the same spec but the second has higher contract ratio and the third has greater brightness.
Not sure out of these 3 differing points gives the greatest benefit.
I'm open to suggestion of other monitors too, was just looking at the Iyama's.
Thanks guys.
i've got the LCD b27 only complaint would be the vertical viewing angles- the whites discolour noticeably. Couldnt complain otherwise.
