Hi, I have a CM 430 elite case, and will be replacing my cf setup with a GTX 580, I just wanted to know how long the following cards are (length wise), if a 750W PSU is enough, and will my case house them ok?
Gigabyte SOC GTX 580
Asus GTX 580 Direct CU II - found out how long they are
Asus ROG Matrix GTX 580 Matrix - found out how long this was too
Gainward Phantom GTX 580 - got this too
Thanks a lot
Thanks a lot
