Hi
I am very close to ordering one of these two. I was looking at spending at the most £1500 which would point to a top spec Ultima, but I am aware that this would be never really be upgradable in the future due to thermal limitations.
So I was thinking I could spend £1800 and get the 17" Pro with same specs and hope that in the future I could put a 9800 gtx or sli in?
And now I have just seen I could get the Ultima Extreme Mobile Plus for £1889 with P8600 and uprgrade that later with a quad core and another GTX?
As you can tell I am not quite sure yet! Do they all come with the new intel chipsets (im45 or something) and with DDR3 system memory?
Thanks
Andrew![Big Grin :D :D](/styles/default/xenforo/vbSmilies/Normal/biggrin.gif)
Thanks
Andrew
