Permabanned
- 5 Jul 2011
Asrock N68C-S UCC
Asus M4N68T-M LE V2
Specification wise?
Thanks!
Asus M4N68T-M LE V2
Specification wise?
Thanks!
they are both very similar. but the main advantages of each board are:
Asrock N68C-S UCC:
- PCIe x1 slot will not be blocked by double slot graphics card (most decent graphics cards are double slot these days)
- cheaper on overclockers (may not be so elsewhere)
Asus M4N68T-M LE V2:
- its the only one of the two that supports 125W processors, like the Phenom II X4 955 BE
depends on what you think will be most useful to you.
Yes I will be using the 955 be
Are there any similar mobos that support double graphics cards also with a similar budget
Thanks.
Thanks.
Sapphire RADEON HD 5770 FleX Graphics adapter - 1 GB - GDDR5 SDRAM
yepso a dual slot would work on this mobo definitely.
Just ordered the asus and the Graphics on the pci ex x16, the sound card and the TV card on the pci's and still need to work out what I'll put on the pci ex x1
Thank you!
My £190 Gaming rig is complete ^_^ lol
