Which OS?
Permabanned
26 Jan 2009
Im currently running Windows 7 Utimate 64bit BETA untill my new mobo gets here.
Im going back to Vista (previous was a dodgy copy ;)). Question is..
Whats the difference(s) between..
Vista Home Premium 64bit
Vista Ultimate 64bit
As i used to have ultimate, but i never needed a key, now it doesnt work since i put 7 on a new drive :confused:.
So can you help me?
KbW
Ultimate costs more, for a pile of features you'll never use.
Which version did you use prior?
I'd get Home Premium - Ultimate is expensive overkill.
If you need Remote Desktop/Domain stuff then get Business. Business doesn't have Media Center, but Home Premium does.
Go Home Premium 64 bit. Backup & Restore can be found elsewhere for either cheaper or for free, with regards to Bitlocker, do a google search on it, I can't answer you for sure there.
Bitlocker is basically an encryption program and uses the TPM BIOS so only works with certain hardware configs. I wouldn't worry to much about it.
I'd get Home Premium x64 which will suit you perfectly.
M.
