Which OS ?
5 Dec 2009
Hey im about to order a Titan Nero but im unsure of which OS to get, i mean whats the differance between the 64 bit home Edition and the 32 bit.
Is the 32 bit better as it costs more ?.
THX
Unless you have incompatible hardware (printers etc) then there is no reason not to get 64bit these days.
Also, if you want to be able to use all 4GB of RAM then 64bit is a requirement.
Definitely Windows 7 64 bit.
My friend wanted a new PC and I recommended the Titan Nero with Windows 7. I went round and setup/installed everything for him and everything worked perfectly.
Didnt need to get any extra drivers. Lan, sound, etc, they're all included. The only drivers I downloaded were the ATI Catalyst, to get the most out of the graphics card.
I bought Windows 7 Ultimate yesterday thinking i will try 64bit but known my luck i will have to switch to 32bit, but dont need to Windows 7 64bit all the way.
