Which part of my OC is failing?
4 Dec 2008
Specs in sig, got the following overclock:
CPU - FSB 244 x 14 (3412MHz), HT Link 975MHz, 1.4V
RAM - 7-8-7-20 1624MHz 2T Mode
Okay so anything over this will BSoD two hours into prime'ing, no "Worker stopped" or anything like that, just the following BSoD (Same one EVERY time):
On Sun 13/02/2011 13:47:53 GMT your computer crashed
crash dump file: C:\Windows\Minidump\021311-16317-01.dmp
This was probably caused by the following module: hal.dll (hal+0x12903)
Bugcheck code: 0x124 (0x0, 0xFFFFFA800554D028, 0xB269C000, 0x175)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\hal.dll
Which part is falling over? Guessing it's the RAM or some voltage?
Cheers
So your memory is running over its rated speed and the timings are tighter than its rated at.
That could be the problem, try loosening the timings.
'Tis only slightly over. They're only running at that speed since someone on overclock.net recommended so, and they've got me a bit further; but still the same problem. Tried without too btw.
Try stressing your memory and CPU individually and see if that tells you which are giving the error. As above it'll likely be the RAM imo.
