Will you be using the stock Wraith Stealth cooler that's included in the box? This cooler has pre-applied thermal paste, which should work well enough for the 2400G.Hi guys i need to order a Tube of paste for a 2400G so which paste to use and what method to apply it as the the surface of the 2400G is bigger than i am used to as i normally use intel with the pea size method.
Thanks in Advance
The usual suspects mentioned above (MX-4, Kryonaut) would be totally fine.This is a second hand part and i will be using stock cooler for the time being so cooler needs re pasting.
