This one:
Processor Specifications
Processor AMD A8-6600K
Processor Cores Quad Core
Processor Speed 3.90GHz
Processor Turbo 4.20GHz
Graphics Specifications
Graphics Card Radeon HD 8570D
Graphics Memory n/a
Drive Specifications
Hard Drive 1TB SATA3 6Gbps
Optical Drive 24x DVD/CD Rewriter
Networking
Wired LAN 10/100/1000 Mbps LAN
Wireless LAN (WiFi) No WiFi
Other Specifications
Video Outputs VGA (D-Sub), DVI-D, HDMI
Memory 8GB
Power Supply 500W
Case CiT 1017 Black Part-Mesh Gaming Case with 500W PSU
Motherboard Gigabyte F2A55M-HD2
- HD Audio
- 1x PCI Express x16, 1x PCI Express x1, 1x PCI
- 4x back USB 2.0 ports
- 2x front USB 2.0 ports
Dual Monitor Support Yes
or this one
CPU
CPU Family: AMD A8
Processor Number: A8-6600K
CPU Speed: 3.6 GHz
Socket: FM2
Technology: 32nm
Number of Cores: 4
Number of Threads: 4
Turbo Core: 4.20 GHz
Memory
Description: Kingston ValueRAM
Memory Size (Total): 8192 MB
Memory Type: DDR3
Memory Speed: 1600 MHz
Number of Modules: 1 module(s)
Module Size: 8192 MB
Error Correction: Non ECC
Voltage: 1.5 V
Pin Configuration: 240 pins
Hard Disk
Disk Capacity: 1000 GB
Disk Speed: 7200 RPM
Data Buffer/RAM: 64 MB
Average Latency: 4.16 ms
Graphics
Description: AMD Radeon HD 8570D
Optical Drive
Optical Drive Type: DVD-RW
Supported Formats: DVD/CD
Motherboard
Chipset Manufacturer: AMD
Chipset: A58
Motherboard Model: Gigabyte F2A58M-HD2 Motherboard
Network (Wired)
Integrated Network: Realtek Gigabit LAN Chip
Network Speeds Supported: 10/100/1000 Mbps
Sound
Integrated Sound: Realtek ALC887 codec High Definition Audio 2/4/5.1/7.1-channel Support for S/PDIF Out
Rear Panel I/O Ports
Keyboard/Mouse Combo Port: 1 x PS/2 Keyboard + Mouse
USB Ports: 4 x USB 2.0
VGA Port: Yes
DVI Port: Yes
HDMI Port: Yes
DisplayPorts: No
Ethernet Connectors (RJ-45): 1 x RJ-45
Power Supply
Power: 550W
Modular Cables: No
Efficiency Rating: No
Graphics Memory n/a
Networking
Memory 8GB
Power Supply 500W
- HD Audio
or this one
CPU
CPU Family: AMD A8
CPU Speed: 3.6 GHz
Socket: FM2
Technology: 32nm
Number of Cores: 4
Memory
Memory Type: DDR3
Voltage: 1.5 V
Hard Disk
Graphics
Optical Drive
Motherboard
Chipset: A58
Network (Wired)
Sound
VGA Port: Yes
DVI Port: Yes
HDMI Port: Yes
DisplayPorts: No
Power Supply
Power: 550W
Modular Cables: No
