Which port multipliers for a Perc6 ?
10 Nov 2004
Expat in Singapore
Hi,
I have a Dell Perc 6/i being used for my home NAS.
Im my impulse buying wisdom I now also have a Norco rack mount server case with 20 SATA hot swap bays.
I plan to have the majority of drives as the WD Caviar Green 1.5TB (have 5 already so would rather not change now).
The Perc 6/1 can take 8 drives. The drive sustained data transfer is listed as 110MB/s. Sata II is 3Gbps (375MB/s) so in theory I could put three drives on each Perc 6/i sata cable. To do this I imagine I would need port multipliers.
Any obvious flaws with the idea (except on it being stunning overkill for a home environment).
Any recommendations on compatible port multipliers (like this from addonics, remove the case mount bracket and attach to custom stand-offs on the chassis I would have to make) ?
I am thinking of a way to get to use the 20 bays if I want to sometime in the future and getting 2 Perc /i cards and finding a motherboard to support them with on-board video, I think, is unlikely to be cheaper than the port multipliers.
Thanks
RB
Thanks all,
Turns out the Perc 6/i is really a Perc 6/ir, refuses to see any on my 5 hard drives and refuses to be flashed with the LSI 1068e firmware.
I have now bought a couple of LSI 1068e 8 port cards (US$95 each) and will use software raid.
Cheers
RB
The newer Dell drivers should lift any drive firmware restrictions.
ftp://ftp.dell.com/sas-raid/
Tried any of those?
Will take a look, thanks. Have tried the firmware from the support site 00.25.47.00 (29/09/2008). This is the firmware already on the card. I have read that the latest LSI 1068e firmware will not load on the card but the previous LSI firmware will. I cannot find the previous firmware anywhere. The current 1068e firmware I can only find on softopia but not on the LSI support site at all.
Does a SAS expander need drivers? I would not have thought that.
The expanders should not but the SAS HBA/Raid card will (although to my knowledge, not specifically special ones to enable expander use. That is an ability of the chipset the HBA/Raid card is based around).
I took a look at the HP SAS expander as there are a lot going on ebay but they are quite expensive (300+), there are two versions (yellow and green PCB) with one being unflashable. Needs bios 1.53 (IIRC) or higher to use Sata2/3 speeds. Can only flash when connected to a HP HBA/Raid card (ebay around 300+). Considering my luck so far with Raid cards and HBA's, I really would rather not chance it :D.
RB
