Hi,
It has been a while since I did a home build, 6-7 years, maybe more I cant remember exactly but my current PC is as my sig minus the 6800 as it died earlier this year.
I have specced myself up a new PC but I'm a little unsure as to what power PSU I'll need. Spec is as follows:
i7 930 2.8Ghz - plan to overclock to 4.0 - 4.2
Asus Rampage II extreme mobo
MSI GTX480
6gb Corsair Tri channel DDR3 1600mhz ram
I'm thinking a Corsair TX 750 will be OK but do I want to stear clear of the TX range and go for the HX range?
Helps appreciated!
Cheers
MSI GTX480
Helps appreciated!
Cheers
