Which power supply?
13 Jan 2012
United Kingdom
Hey guys which power supply do you think I should go for. It needs to run an overclocked 2500k and gtx 670 ftw. Budget around £70 - £90. Was thinking the corsair gs700 but is their a modular psu around this price range?
Another question I have is would a 700watt handle a possible sli in the future or should I be better looking at an 850 watt
How does the ocz perform compared to Xfx and corsair? Are they reliable
Well corsairs GS range is their mid-budget product, with the TX, HX and AX series all far superior. And the PSU isn't modular.
THe XFX is a good PSU mmade by seasonic.. Not moudlar though..
The OCZ is from a high quality ZT series and fully modular. Also at a very good price.
The OCZ would be my choice. :)
