- 6 Feb 2009
I got a Q9550 E0 last week and clocked it to 4Ghz. It passes 20 runs of LinX with all memory. I also ran MemTest86 for 5 hours without any errors.
I'm wanting to run Prime95 as another CPU stability test but don't tend to use it so not sure which mode to go for. The memory is fine so should I run small FFT as it just tests the CPU or is it better to run large FFT as it's hotter and tests some RAM too?
Thanks
Thanks
