- 7 Jan 2009
- Stafford
Hi all,
I'm after a new machine for running Virtual Machines, heavy Web Development useage, as well as programming using Microsoft Visual Studio 2010 and also Adobe Flash work. Budget is very tight - so I have been looking at Dell Precision Workstations (second hand). Many of them seem to have Xeon processors.
Not sure which would be best, 2x Dual Core Xeons or one Core 2 Quad processor. One workstation spec is listed below:
"750W power supply, 2 x dual core Xeon 5160 processors, 8Gb DDR2 667 quad channel FBD memory (made up of 8 x 1Gb modules), 4 x 146Gb 15,000 rpm SAS drives"
Clearly if budget was not so bad I would be looking at I7's but what are your thoughts on Xeon processors vs Core 2 Quads?
Not really looked much into AMD...
Thanks in advance!
Thanks in advance!
