Which programs utilise UVD (HD3850 PRO)
Im still waiting for CoreAVC to add support. Then every media player should be able to take advantage.
Cant you get the cyberlink codec which supports UVD and use that?
As for powerdvd7, do all versions support UVD or just the ultra version?
edit: the powerdvd7 ultra codec doesnt work well with haali media aplitter.
powerdvd, windvd and nero showtime are the main commercial codecs that will allow hardware video acceleration. Could be others but id say these are main ones supported. Once the codecs are installed pretty much any media player will utilise them.
