Permabanned
- 2 Dec 2007
OK I have 3 x PSUs here from various systems and the one I keep will be powering:
e2140 @ As higher clock possible on air
Gigabyte board with 2 x 1gb ram
4 x HDDs
1 x DVD drive
1 x floppy
3850 gfx card
couple of fans
1: Akasa 460 watt
This has Dual 12v rails from what I can make out, as the +12V1 = 14A and the +12V2 = 15A.
The good thing about this PSU, is it has a 120mm fan and runs very cool. It has been fautless in a socket 939 system overclocked with same amount of drives and an overclocked x850 card. About a year old.
It is similar if not the same as the one at OCUK HERE.
2: Tagan 480 watt
I believe this has single 12V rail from the pic below of 28A. About 2 years old. Has 2 x 80 mm fans front and back and seems fairly quiet. Hard to tell with other system fans on.
3: Antec Earthwatts 500 watt
Looks like a dual rail one again with 17A on each making 34A? Its this one HERE and comes with 2 x PCI-e adapters which kind o fsuggests its capable of SLI maybe. This is new and so has 3yr warranty. Has this new environment friendly ultra efficiency stuff going on. 2 x 80mm fans I think. Not sure on noise. Couple of reviews say it could be quieter than some 120mms but only read like 2 reviews. I read somewhere that these are basicalyl rebranded Seasonics? Not sure of the truth behind that. They dont look very fancy but function over form here really.
None of them are modular.
Thanks for your advice
4 x HDDs
1 x DVD drive
1 x floppy
3850 gfx card
couple of fans
1: Akasa 460 watt
2: Tagan 480 watt
