Which PSU? HAS to be modular.
6 Nov 2004
Right just build my FT03 and I'm absolutely gutted the PSU is all wrong for this case! The place where the power supply is means I cannot shut the side vent thing. Bad desgin on Silverstones front as they could have just had the little flap thing offset to the left... But anyways the case is a tight fit with my having a BeQuiet! 600W normal PSU. So I was wondering which modular PSU should I be looking to replace this with? And the power cable has to be not in the same area as this picture.
Looking at other PSU's it's apparent BeQuiet! Thought they'd be a bit 'original' and plant the power cable portrait rather than landscape...
All I need is a normal modular PSU so which one is best to replace mine do you think? Can't DIY fix that it appears the only PSU in the world that has the power cable at that angle is the one I have... I need a modular PSU anyways really struggling to close the side panel of this case.
