Which psu will i need
13 Nov 2012
Welling
i have recently baught a 7970 matrix platinum and i am continuing my build by buying a psu soon, but how much wattage will i need, i will have both the gpu and the 4670k overclocked, i know i have made a thread about psu's before however i just want final ideas before i buy it, i have a budget arround £80-£110, cheaper prefered :), can anyone spec me a decent psu, some corsair ones are meant to be good but i have no idea which series.
Those look like good Choices, thank you stylid :),
But would you recommend pushing the budget an getting a fully modular psu ?
