Which PSU?
23 Sep 2006
Lincoln
Looking for advice on which PSU to look for for my new rig which will consist of ...
E6400 Conroe
Asus P5B Deluxe
GeForce 7900 GS
2 x 1GB RAM
2 x HDDs, 1 x DVD, 1 x multi-card reader
Grateful for advice on a decent PSU to go for. Not sure if I should look for a 600W or bigger PSU. Would also like one that is fairly silent and does not cost the earth (possibly around the £30 mark).
a) enermax 620w is a good psu
b) Seasonic S12 600W Silent ATX2.0 Power Supply (CA-002-SS)
i dont think there is one for £30
I dont know if you are overclocking? either way I would say 500w is a minimum...
if not overclocking you may just wanna go for :
a) e6300
b) asrock mobo
saves u a few more quid...
also please note dont overlook the fact that if you buy a cheap psu and it dies it could take something with it i.e. mobo...in which case spending an extra 30 quid for a psu would be sooo justified...
E6400 Conroe
Asus P5B Deluxe
GeForce 7900 GS
2 x 1GB RAM
600 watts is overkill, I took the test for you but i cant fill it in all perfectly because i dunno how much else stuff u have, but with all basic hardware ( 2 fans, your stuff u posted above, 1usb device, etc....)
you need
eXtreme Power Supply Calculator v2.0 said:
Recommended PSU Wattage: 294 watts
Fill it in urself if u dont believe me : http://www.extreme.outervision.com/PSUEngine
But a 350 watts psu from a good brand would be more than enough for the energy-efficient core 2 duo....
Highly recommend seasonic, ocz or zalman for a psu...
CaSh_MoNeY said:
Yep i agree, the 400W Akasa i spec'ed above will be plenty.
A bit over his price limit tho, what about the :
FSP Sparkle ATX-400PNF 400W ATX2.0 PSU
Price: £27.99
Thanks for the link. Filled it in (including USB, fans etc) and it looks like I would need 356W. However, any overclocking of the CPU pushes the requirement up towards the 400W mark. Adding a dedicated sound card and a PCI card pushes it over 400W. Therefore, I presume I should be looking at one that delivers 400 - 500 W which gives me scope for future addition of a extra drives etc.
Then you need more as 30 quid sry,
These look ok:
OCZ ModStream 450w ATX2.0 Power Supply 44 quid
Akasa Ultra Quiet 460W Paxpower Active PFC ATX2.0 PSU 47 quid
Seasonic S12 430W Silent ATX2.0 Power Supply 43 quid
Zalman ZM460-APS 460W ATX2.03 PSU 54 quid
yozzer2001 said:
WAITS FOR SOMEONE TO SAY QTEC :o
Not me i've had a q-tec and wont ever recommend someone to buy it, isnt sold on ocuk now either...
