which psu ?
20 Aug 2010
just started buying parts for my first pc build.ordered a Coolermaster CM-690 II Advanced Dominator Case..... gonna be using it mostly for gaming, so getting a phenom 2 x4 955 black edition cpu. so was just wondering what is a good psu to get. dont want to go to mad on price
havent made choice on the card yet..but at some point i will be upgrading whatever i get first to a 5870 so want a psu that will be able to handle that when the time comes
It's a nice case.
(Stulid's PSU suggestion will handle 2 in Crossfire, but if you really hammered the system in a stress test you'd be getting a little closer to the limits of the PSU than I generally prefer to go).
yes, but the next questioning is what motherboard are you getting, got.
not all of them support crossfire, meaning you may not even need 650w
for motherboards i have beenn looking at the
Gigabyte GA-MA770-UD3 AMD 770 (Socket AM3/AM2+) PCI-Express DDR2 Motherboard [GA-MA770-UD3] and the
Asus M4A87TD Evo AMD 870 (Socket AM3) DDR3 Motherboard [90-MIBCK0-G0EAY0WZ]
so really i shouldnt go for any psu under 650 is what your both saying right ?
No!
You say price is an issue. There is much more to a psu than the claimed wattage. You can find 700w supplies for 20 quid, do not buy one of them.
I dont think you need a 650w supply myself, but its fashionable to over specify supplies. Ill vote for any 500W+ one with corsair written on it.
No!
+1
I only buy corsair PSUs, they are very good, well worth the price. Do you really want to skimp on the device that controls the voltages & current provided to your new PC components? very cheap=inacurate voltages, worse over/under volt/current protection etc... I'm not neceserily saying that the above quoted PSUs are bad, I've never had an experience with them, but the non-branded £20 for 700W+ are bad, I've had experience with their smaller brothers (around the 400W range), and had lots of them blow on me, now running corsair, and it's been great for years.
