Which PSU?
29 Dec 2005
Hi.
I've currently got a Coolermaster 650W psu (think its extreme power model but not certain of this), which is on its last legs.
My specs are:
e6600 @ 3ghz
2gb ddr2 ram (4 x 512mb)
500gb hd
8800gts 512mb
p5n-e sli mobo
Just wondering which psu you guys would recommend for this setup? I was thinking any branded ~500W psu should do the trick. And I am on abit of a budget as well.
Also if I upgraded ram to 4gb, graphics card (2nd 8800gts) what kind of psu would be better?
Thanks
Hi.
My specs are:
e6600 @ 3ghz
500gb hd
8800gts 512mb
p5n-e sli mobo
Thanks
i reckon you need to upgrade to at least 750w
No he wont, the GTS are not that power hungry, and the E6600 does not pull much as well.
