which PSU?
31 Aug 2010
i currently have a 750w thermaltake toughpower PSU
if i get a 2nd R9 290 do i need to upgrade this? and if so which one would be best?
thanks
Budget? so suggestions don't get out of hand.
What case do you have? some higher wattage PSU's come in large sizes that may not fit.
I think you'll struggle to get a quality unit for that budget.
The Antec High Current Gamer 850W 80-Plus Bronze is £125.99, which, if you can stretch to that, would be worth looking at. I can't post a link at the moment as the OcUK website seems to be having some difficulties.
