Which PSU?
20 May 2011
Aberdeen, Scotland
Simple question,
don't do SLI or anything, so only needing a 850w for an overclocked x99 build, should keep me in the well efficient range of power usage, I believe? (Will OC both CPU and GPU, but again, only one GPU).
If so, I'm looking at the leadex platform. Iirc, the EVGA supernova 850w G2 is built on that from Superflower, and is cheaper than the respective official Superflower 850w PSU which is what I was looking at as well.
Between the two of them (since they seem to be the best in that range) which one should I go for?
Okay good, guess my musings on how much wattage I'd need was correct, then. :p
I'd heard something about newer EVGA PSUs using Seasonic or something, 850 G2 still on Leadex?
That was 2014. Any chance they might have switched vendor in 2015?
Just making sure of course, would be nice of the EVGA rep to swing by.
