Hi all.
I find the Laing DDC 18W (Swiftech MCP355) far too noisy. So, I'm on the lookout for a different pump, and it should be a quiet one.
Loop is: Thermochill 360 radiator, EK GTX470 WB, Alphacool Nexxos Highflow AM2 WB, Danger Den Rad reservoir.
I may add a second GTX470 later, which would be combined with a 120 radiator too.
If possible, the pump would intake at the top, and the outlet would be at the side, but it shouldn't matter too much.
Oh, and I use 1/2" tubing, G1/4" threads.
Thanks
Simon
Thanks
Simon
