which radiator is better ??
Mr Mister said:
depends what fans you are wanting to use with them.
I know HE rad is better with fans which are 100cfm+
Not sure on the BIX
erm, 100CFM ??? per fan??? is that not gonna be bloody noisey?
basically i can get either a
Black Ice Extreme Rad 240mm with 2X free YSTECH KM121225LS fans for £25 or
Thermochill Radiator (HE 120.2) and use my 2 existing Akasa Ambers for £22.
i really have no clue, hell i dont even know what CFM the ambers have, i just know they are quiet and thats what im after.
yea it is noisey! :p
I would personally go for the BIX with the set of 2 fans and then you can see how good those fans are and you have the option of swapping over to your ambers.
You could get a new one of these:
HWLabs Black Ice Stealth GT240 (Black)
Price: £29.78 (£34.99 Including VAT at 17.5%)
They are relatively low profile rads to make it easier to fit in a case and also offer good performance with low noise fans.
locutus12 said:
i would but im relatively poor at the minute, hence second hand... :(
Save your cash, save up for a new PA series Rad.
When you get it and pull it out of the box, you'll get that shiny 'thermochill' feeling I got when I finally purchased my PA120.3 a couple of days ago. Arrived yesterday, and now the weekend just can't come quick enough!
