Hi, I’m trying to decide whether to go with PC6400 or PC8500 for a new system running a quad core E6600. I probably won’t be overclocking, or will overclock very little. Im under the impression from reading around that the faster 1066Mhz RAM will not run at that speed unless you considerably overclock the CPU, therefore I should save the money and go with the 800Mhz stuff. Is this correct?
Also which brand would you recommend? I’ve had good experience with Corsair in the past but as im not intending to do much overclocking I’m now wondering if I should go for a cheaper brand?
