Hi everyone,
I just bought the below setup and have a question I hope you could help with.
Phanteks Eclipse P350X Glass Digital RGB Midi Tower Case - Black
Gigabyte Z390 UD (I'm presuming)
**Build Promo**Intel Core i7-9700K 3.6GHz (Coffee Lake) Socket LGA1151 Processor
Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey (TLGD416G30
Gigabyte 256GB M.2 PCIe x2 NVMe SSD/Solid State Drive
Samsung 500GB 860 EVO SSD 2.5" SATA 6Gbps 64 Layer 3D V-NAND Solid State Drive (MZ-76E500B/EU)
GIGABYTE GeForce RTX 2080 GAMING OC 8G
Comes with a 600W PSU but I have a spare Corsair 650W modular supply I could swap it out with.
The watercooling for CPU is the Asetek 670LT cooler - front mounted.
My question is, should I swap the default rear exhaust fan?
I asked OCUK what fan it comes with and they said to ask Phanteks,which I did and the details are below:
Dimension: 120 x 120 x 25 mm
Rated voltage: 12V
Operation voltage: DC6.0V-DC13.2V
Speed: 1300 ± 10%R.P.M.
Max airflow: 50.557CFM
Static pressure: 1.257MM-H20
Acoustics: 23.5dBA
Weight: 109.6g
Assuming the Asetek radiator has Static Pressure fans on (which all radiators should imo)
Would I be better swapping out the default rear fan for a spare Akasa Viper I have which has higher CFM and actually has high SP rating I believe.
The main trade off would probbaly be the noise level by about 6dB at full RPM. Reason for this is that I know Air Flow fans are better with no restrictive covers / filters in the way.
Or would I be better sticking to the stock one provided?
Any feedback is appreciated and I know the ideal solution is to test with both fans and compare temps during stress tests but just wondered opinions.
Thanks
Rated voltage: 12V
Acoustics: 23.5dBA
Weight: 109.6g
Thanks
