Which reference 980ti?
  • Thread starter Thread starter Asa
  • Start date Start date
Asa
Asa
15 Nov 2011
Buying time!
As far as I know all the reference cards are essentially the same. Is there any reason to choose the Zotac over the OCUK, or vice versa?
Sticking with reference because I will be adding a second in a couple of months.
Buying time!
Logic would dictate you buy the Zotac over the OCUK version. It's the same price but has a five year warranty over the two year offered by the OCUK one.
Only difference really is the warranty that comes with the card and the rma process. Ie Zotac has a 5 year cover, gigabyte has uk rma.
