Which Remote Control Question
29 Sep 2004
Wilt of the Shire
I'm fed up with the slow response time using my MCE Remote with my HTPC (and having 4 remotes all over the place). So, I've decided I'm gonna look for a remote that will control all my bits. I've seen logitech bandied about a bit but not sure which one to go for. I don't want to spend too much and it's gonna have to be easy enough for the missus to use!
I want use the remote with Sky+, my HTPC, Panasonic 32" telly and Samsung HTZ310R speakers. Would a logitech remote be ok to do all this without too much fuss setting it up?
Cheers
Yep Logitech have some fancy remotes that can learn the devices they're talking to with effectively one touch setup. Downside, they cost the earth! at least for a telly zapper anyways.
Thanks for that but any idea which model to go for?
