Hi,
After having had a new comp built by my insurance (lightning strike to next doors house, so fried loads of things in ours!), I would like to improve on it.
I have replaced the stock Phenom 955 cooler for a Arctic Cooling extreme one, chainged the chipset cooler for a Thermalright one, fitted a Zalman passive cooler to the graphics card (with a low noise fan)
The main noise from the machine now is coming from the PSU, which is a OCZ 700SXS, and has a 120mm fan.
I would like to make it a bit quiter. I cannot exchange the unit, as it was built for me by a THIRD party !!! (ie insurance subied it out, and they then did the same !).
After giving my life story.....
What is a good replacement 120mm fan for going in a PSU (I'm a 'spark', so am aware of the risks of capacitors etc inside)?
Would like it as quiet as can be
Goes into a CoolerMaster HAF case (a superb case if you ask me!!)
It is a 700W PSU. One graphics card, 2 HDD, one optical drive. It is mounted at the bottom of the case, and draws air (and crap) from under the case, and straight out the PSU.
Sorry to have waffled !
Andy
Andy
